11-19-2018 06:41 AM - edited 03-14-2019 06:38 PM
Hi All
I have a query. Please find attached the image for the reference.
CallQueue and Calling number will come from ICM as a input .
so from which variable we will receive above two variable to finesse desktop ?
Thanks all in advance !!!
Solved! Go to Solution.
11-19-2018 08:16 AM
Are you asking which variable will contain Call Queue and Calling Number (DNIS)? If so, that's entirely up to you...
11-19-2018 08:16 AM
11-20-2018 01:53 AM
11-21-2018 06:59 AM - edited 11-21-2018 06:59 AM
Let's use Call Peripheral Variable 1 and 2
You'll want to place a Set Variable node in your routing script calling on Peripheral Variable 1 and your value being Call.DialedNumberString. Place another Set Variable node in your routing script calling on Peripheral Variable 2 where you can enter a literal string (double quotes) for your queue name.
To display it in Finesse, log into CFAdmin, go to the Variables layout change the name for Variable 1 to be Dialed Number and Variable 2 to be Queue Name
