VRU connect port for two CVP Pim's
harresh123
Can I use the same VRU connect port if I have two CVP PIM's configured on the same PG. I have tested this in lab and do not see an issue with failover but wanted to make sure. I know there are some components in ICM which needs a unique port number b/w A and B side like Client Connection Port for CTI.
Piyush Verma
Level 4
Level 4
In this communication, PG is a client and CVP is a server. So yes, you can have two CVP PIMs with the same port number (default port for the CVP is 5000).
Piyush Verma
Level 4
Level 4
