Showing results forĀ
Search instead forĀ
Did you mean:Ā
2 servers can not reach via Nexus 3172T Chassis orphan port
Kwuenph
Hi all,
We're using 2 Nexus 3172T Chassis in vPC domain, 2 servers running esxi hosts, each server connect to 1 vPC N3k switch using 1 link.
All port-group and standard switch configuration in esxi are fine, but 2 vms in same subnet can not reach each other via vPC Switches.
Could someone help to clear this issue ?
          |     n3k1        + keep-alive|     n3k2         |
          |                 |  vPC link |                  |
          |      e 1/2      |           |       e 1/2      |
                  | trk                      trk   |
          |  vSw-1             |        |   vSw-1           |
          |  | VM-1          | |        | | VM-2          | |
          |  |172.19.5.49/16 | |        | | 172.19.5.53/16| |
          |                    |        |  ESXi Host-2      |
          |   ESXi Host-1      |        +-------------------+
-------- N3k -1 vPC config--------
vpc domain 888
peer-switch
role priority 1
system-priority 4000
peer-keepalive destination 1.1.1.6 source 1.1.1.5 vrf KEEP-ALIVE
auto-recovery
ip arp synchronize
BDT-HCM-N3K3# show vpc brief
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 888
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : failed
Type-2 inconsistency reason : SVI type-2 configuration incompatible
vPC role : primary
Number of vPCs configured : 9
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled, timer is off.(timeout = 240s)
Delay-restore status : Timer is off.(timeout = 30s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po4096 up 1,10,20,30,40,50,691,693,696,706,712,878,1313-131
4,2000,3261-3262
 show vpc orphan-ports
Note:
--------::Going through port database. Please be patient.::--------
VLAN Orphan Ports
1 Eth1/2, Eth1/9, Eth1/11, Eth1/14, Eth1/16, Eth1/18,
Eth1/19, Eth1/21, Eth1/23
10 Eth1/2
20 Eth1/2
30 Eth1/2
40 Eth1/2
50 Eth1/2
691 Eth1/2
693 Eth1/2
696 Eth1/2
706 Eth1/2
712 Eth1/2
878 Eth1/2
1313 Eth1/2
1314 Eth1/2
2000 Eth1/2
3261 Eth1/2
3262 Eth1/2
-------- N3k -2 vPC config--------
vpc domain 888
peer-switch
role priority 2
peer-keepalive destination 1.1.1.5 source 1.1.1.6 vrf KEEP-ALIVE
auto-recovery
ip arp synchronize
vpc 3
show vpc brief
Legend:
vPC domain id : 888
vPC role : secondary
4,2000,3261-3262
Note:
VLAN Orphan Ports
1 Eth1/2, Eth1/9, Eth1/11, Eth1/13, Eth1/14, Eth1/15,
Eth1/16, Eth1/17, Eth1/18
10 Eth1/2
20 Eth1/2
30 Eth1/2
40 Eth1/2
50 Eth1/2
691 Eth1/2
693 Eth1/2
696 Eth1/2
706 Eth1/2
712 Eth1/2
878 Eth1/2
1313 Eth1/2
1314 Eth1/2
2000 Eth1/2
3261 Eth1/2
3262 Eth1/2
balaji.bandi
Do you have any HSRP running for this network :
172.19.5.x
where is the Gateway resides for this network ? and what vlan for this network ?
BB
Thanks balaji.bandi for your response.
There is no HSRP in switches, just 2 servers in the same subnet access the same vlan 30
Is this only VLAN having issue or none working on Esxi side ?
Then  we need to look the configuration on ports connected to Esxi both the side, please post the configuraiton.
Explain how Esxi vSW configured, and have you configured  promiscuous mode ? and allowed all the VAN in that vSW.
BB
I've tried to Accept Promiscuous mode in both vSwitch.
None of VLANs work at all.
All configuration and testing case as in attachment file
