Breakout on N9K-C9372PX-E
Netmart
Beginner
Beginner
Could someone please advise on why breakout feature seem not to work:
Software
  BIOS: version 07.69
 NXOS: version 9.3(10)
  BIOS compile time:  04/08/2021
  NXOS image file is: bootflash:///nxos.9.3.10.bin
  NXOS compile time:  7/8/2022 9:00:00 [07/08/2022 14:10:17]
# sh module
Mod Ports             Module-Type                      Model           Status
1    54   48x1/10G SFP+ 6x40G Ethernet Module   N9K-C9372PX-E         active *
Mod  Sw                       Hw    Slot
1    9.3(10)                  1.0    NA
Mod  MAC-Address(es)                         Serial-Num
1    00-c8-8b-cc-22-14 to 00-c8-8b-cc-22-51  SAL2005Y1X7
Mod  Online Diag Status
1    Pass
(config)# int breakout module 1 port 49 map ?
% Incomplete command
(config)# int breakout module 1 port 49 map 10g-4x
% Invalid parameter detected at '^' marker.
Thank you f00z for providing this document.
I am perplexed that Cisco TAC obviously does not understand their own architecture; Cisco TAC recommend to upgrade this NX switch to RN 9.3.10 in order to gain the breakout functionality. I hope some of Cisco Engineers reading this post and charming in to this discussion. Thanks Netmart.
f00z
Beginner
Beginner
Breakout is not supported on ports connected to the NS ASIC (ALE) .. I.E. the 40g ports on 9372, the 6 40g colored ports on 9332PQ etc.. There's a document here that explains the limitations , of which there are A LOT unfortunately:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/ale_ports/b_Limitations_for_ALE_Uplink_Ports_on_Cisco_Nexus_9000_Series_Switches.html
