How Disable http services on Nexus 1000V
helenio
Is it possible to disable http acces on N1K ?
In case is is possible to configure Authentication ?
lwatta
In the current version it is not possible to turn off the http server. In newer versions it will be possible to turn it off. However keep in mind that Vmware Update Manager conencts to the VSM using http to get the VEM code. If you block or turn off http on the VSM it will prevent VUM from working and you will have to install all the VEM modules manually on the ESX hosts.
Also by default the VSM and vCenter communicate via port 80. It is possible to change this to another port but just realize that the VSM connects to port 80 on vCenter to communicate.
So if you block incoming port 80 to VSM then VUM will break
If you block outgoing port 80 from VSM then connectivity to vCenter will break
louis
ohhhh...
Personally I think is important do disable the http server on the switch for security reason even if this will mean to install VEM manually.
This is currently not possible, but an option to disable the HTTP server will be added as an enhancement in an upcoming release
