how to remove vem ?
irek.romaniuk
I'm seeing too many VEMs after cahnging domain id from 25 to 35 how to remove old ones ?
rsn1-1c-n1k# sh svs neighbors
Active Domain ID: 35
AIPC Interface MAC: 0050-5682-0005
Inband Interface MAC: 0050-5682-0007
Src MAC           Type   Domain-id    Node-id     Last learnt (Sec. ago)
0050-5682-000c     VSM        35         0201     178455.64
0002-3d40-2302     VEM        35         0302       850.87
0002-3d40-2303     VEM        35         0402      2712.86
0002-3d40-1904     VEM        35         0502     178596.67
0002-3d40-2305     VEM        35         0602      2712.86
0002-3d40-1902     VEM        25         0302      1995.53
0002-3d40-1903     VEM        25         0402      2725.41
0002-3d40-1905     VEM        25         0602     166360.96
5 Replies 5
Robert Burns
How many VEMs do you see currently only from the VSM?  If you see the "correct" VEMs show from a "show mod", from the VSM, issue "no vem x" for all the module #s that are stale (not inserted).  Save your config and reload your VSM.  This should clear out the stale VEM data.
The reason why you have so many VEMs showing us is because each unique VEM Src MAC is generated by the Domain ID & Slot # it's been assigned to.  Looks like you have stale VEM registrations that need to be cleaned up.
Robert
I see correct VEMs from VSM . But if I do 'no vem 6' I will remove 'correct' vem with Scr MAC of 0002-3d40-2305    not that one with Src MAC 0002-3d40-1905 ?
rsn1-1c-n1k# sh mod
Mod  Ports  Module-Type                       Model               Status
1    0      Virtual Supervisor Module         Nexus1000V          active *
2    0      Virtual Supervisor Module         Nexus1000V          ha-standby
3    248    Virtual Ethernet Module           NA                  ok
4    248    Virtual Ethernet Module           NA                  ok
5    248    Virtual Ethernet Module           NA                  ok
6    248    Virtual Ethernet Module           NA                  ok
7    248    Virtual Ethernet Module           NA                  ok
Can you also paste the output of "show run | i vem"
I'd also suggest to try the following.  From one of the VEM's CLI, issue "vem restart".  See if this clears up your issue.  Note this will cause a 2-3 sec impact to networking, but will come back online immediately.
thanks,
Robert
rsn1-1c-n1k# sh run | i vem
vem 3
vem 4
vem 5
vem 6
vem 7
vem 3
all with same id
  host vmware id 44454c4c-4200-1033-8053-b1c04f4e5131
vem 4
  host vmware id 44454c4c-4600-1053-8033-c8c04f315131
vem 5
  host vmware id 44454c4c-4600-1053-8033-c7c04f315131
vem 6
  host vmware id 44454c4c-4600-1053-8033-c6c04f315131
vem 7
  host vmware id 44454c4c-3900-1033-8053-cac04f4e5131
I did 'vem restart' just after after cahnging domain id from 25 to 35
Irek,
The VEM UUIDs are all unique which is good.  You shouldn't have any issues.
vem 3
vem 4
vem 5
vem 6
vem 7
Robert
