N6K-C6004-96Q Needs license to add and use slot 5 to 8 ?
erick.mephon
We have been running into trouble with the first module in a N6K and are searching for a workaround.
We want to add a module on a N6K-C6004-96Q. Using fixed (non removable) slots 3 to 4 requires a license (L-N6004-12Q-LIC) but what about slot 5 to 8 which are empty and can take a N6K-C6004-M12Q= module in order to add 12 ports, is it necessary to add a license for it too ?
MEPHON Erick.
Christopher Hart
Hi Erick,
Each instance of the L-N6004-12Q-LIC license file authorizes you to use storage services on 48x10G interfaces or 12x40G interfaces. It does not matter whether the interfaces in question are the fixed LEMs in slots 3 and 4, or on an N6K-C6004-M12Q module inserted in slots 5 through 8.
To directly answer your question - if you install an N6K-C6004-M12Q module in an empty slot of the N6K-C6004-96Q chassis, you will need an L-N6004-12Q-LIC license file present on the bootflash to comply with Cisco licensing if you use interfaces on that module.
I hope this helps - thank you!
-Christopher
Christopher Hart
Hi Erick,
-Christopher
Alright thank you Christopher,
Do you know why in the description they say Storage services ? What is being describe as storage services exactly ? Is it the module end usage ?
One side question what does happen to buying a license when the device is EOL & EOS for example ?
MEPHON Erick.
Hello Christopher,
I'm a few years late as I really did not see your reply earlier, thank you.
Best Regards
