Nexus 1Kv for Hyper-v questions
javier.pobeda
Hi all, thanks in advance for helping everybody here.
1) Is it possible to run VSM VM over VMWare, just for manage hyper-v VEMs?
2) Is it mandatory to run on MS 2012 the Hyper-v´s VSMs?
3) What can we do when a VSM VM kept on Loader loading stage1.5? Is any troubleshooting workflow to run?
4) If we have 3-4 different chassis (not UCS), what architecture do you recommend?
5) If for some reason VSM never boot up again, and we have to reinstall it, do we have to do some extra work on VMM like re adding again or reconfigure something? Some Switch guid is attached to some config?
mtrcek
1) No.
2) Yes.
3) Usually this is the problem with communication between VSM and SCVMM.
4) No general recommendations
BR,  M.
