03-12-2020 12:22 AM
we have a requirement to run PIM adjacency between a firewall and nexus in VPC environment , firewall connected to nexus by using VPC port channels and VLAN SVI is used to establish PIM adjacency.
As per configuration guide this PIM adjacency currently is not supported , but i found a TAC technote that says that this will be supported later with Layer 3 over VPC feature and currently traced to below bug but details currently not visible to public.
CSCtq49254 VPC: Mcast not forwarded when received from VPC from L3-hop on VPC Sec.
Has anyone come across this issue.
03-19-2020 07:45 AM
Hi!
Check out https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/118997-technote-nexus-00.html it's recently been updated with new platforms and more information.
Hopefully this helps!
Jason.
03-20-2020 03:12 PM
03-20-2020 07:57 PM
This discussion was helpful.
