secure password so fast to disable on first boot of nexus 9000v
I was installing the image cisco nexus 9000v on eve-ng community edition but during it's first boot it is so fast that I was  not able to disable the secure password question and enter a new password. So, I am not able to enter into the switch and use it. Any help is appriciated
Thank you in deed!
This has solved the problem
5 Replies 5
balaji.bandi
wipe again and start, do not use any keyboard strokes until it clear, because of enter key, it take defaults.
BB
Thanks for your help but it is still the same here is the output
if you using secure password ( then it should be combination)
personally for Lab, i select  N
BB
sp2720401
You also have the third option "skip" when during POAP. Skip POAP and you get right to a prompt and can login with admin and no password. The only problem there is that you have to set a password before you can save the configuration to startup config and you will also have to set the "boot nxos" statement.
Use that
Thank you in deed!
