Stuck at bios Nexus 3000
whitegrape
HI Guys,
I have a switch Nexus 3064PQ stuck at bios.
(c) Copyright 2011, Cisco Systems.
N3000 BIOS v.1.7.0, Mon 10/14M
Unable to boot past this.
Anyone has already idea what's wrong with this?
Thanks in advance!
8 Replies 8
Sergiu.Daniluk
What actions did you performed before the problem appeared (upgrade, config etc)?
Sergiu
It is a refurbished set. Im not sure what did the previous supplier has done to it too.
Thanks!
Hi @whitegrape
If the device is not booting, then probably the device is bricked. There are some unsupported upgrades which can brick your switch (example: CSCva97678). You should return the switch and ask for a replacement.
Stay safe,
Sergiu
Hi Sergiu,
Thanks for your advise! Seems like the device is bricked.
I will look for other way!
Thanks for your help!
Roy
balaji.bandi
Thanks! actually I connect to the console port and it couldn't get past the bios. Im unable to load to the loader.
Im thinking any solution to find out the bios problem.
Raise an TAC case for RMA. If you have smartnet contract.
BB
Hi BB,
I will try to solve on my side.
Roy
