VM connectivity issue
mhasabal
Happy 4th everyone
Please help me out to understand the no connectivity issue i am experiencing for one of the VMs "V1"
please see attached text config file
interface Vethernet7
  inherit port-profile data_vlan172
  description V1, Network Adapter 1
  vmware dvport 512
port-profile type ethernet vm-data-uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 4,172
  no shutdown
  system vlan 4,172
  state enabled
port-profile type vethernet data_vlan172
  vmware port-group
  switchport mode access
  switchport access vlan 172
  no shutdown
  system vlan 172
  state enabled
N1000vUCS# sh vlan
VLAN Name                             Status    Ports
1    default                          active    Eth3/2, Eth4/4, Eth5/2
4    MGMT_VMWARE1000V                 active    Veth1, Veth2, Veth3, Veth4
                                                Veth5, Veth6, Veth8, Veth9
                                                Veth10, Veth11
120  CONTROL_UCS                      active
130  PACKET_UCS                       active
172  VLAN0172                         active    Veth7
VLAN Type
1    enet
4    enet
120  enet
130  enet
172  enet
i am not able to ping the default GW 172.20.1.254
currently the VM has static IP 172.20.1.35/24
N1000vUCS# sh ip arp vethernet 7
IP ARP Table
Total number of entries: 0
Address         Age       MAC Address     Interface
N1000vUCS# sh ip arp summary
IP ARP Table - Adjacency Summary
  Resolved   : 0
  Incomplete : 0
  Unknown    : 0
  Total      : 0
11 Replies 11
abbharga
Level 4
Level 4
Looking at the outputs, is this N1K running on a UCS system?
If so can you verify if you have defined vlan 172 on the UCS system and also attached it to the vmnic under the service profile? Also if its native vlan on the UCS vmnic you will have to mark it as native on the uplink port-profile.
./Abhinav
abbharga
thanks for the reply.
vlan 172 is not defined on the UCS, but from the n1k i am able to hit the 4500 core sw
you will have to define the vlan 172 on the UCS. Can you explain more on what you mean by hitting the 4500 from the n1k?
i am able to ping the gw 172.20.1.254 from the n1k
i was able to define vlan 172 from the LAN tab for both fabrics A & B when adding the vlan on the service profile it shows an overlap
The ping from the N1k to the GW IP is via the mgmt0 interface, where as the traffic for the VM on vlan 172 will be carried on the uplink interfaces from the blade to the 6120 and up north, for this you need to define the vlan 172 on the UCS, add it to the vmnic (which will trunk the interface from the 6120 to the blade) and automatically add / trunk the vlan on the uplink interface on the 6120.
You need not define the vlans individually on the FI-A & FI-B, whie creating the vlan you can configure it as a global vlan which will define it on both the FI.
./Abhinav
sean.wang
If your configurations are correct, and if your ping is not even working without going through any routing hops, check if you have hit a bug that causes VM connectivity and ARP issue. I have posted details below, interested in if there are other Nexus 1000v users hitting the same bug.
http://www.seanxwang.com/2010/07/nexus1000v-bug-widespread-vm.html
@Sean - Are you referring to CSCte96034 "MAC move packet must be sent to broadcast address" ?  This bug was causing MAC move notifications to be discarded based on the destination address being used.
This bug has been fixed in the latest release 4.0.4.SV1.3.  Information on this bug can be found in the bug toolkit -> http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCte96034
If this isn't one you're referring to let me know the bug ID if you have it and I'll see if I can provide any further details.
Robert
Robert, it's a different bug, CSCtg72137. Thanks.
That will be fixed in the upcoming maintenance release 4.0(4)SV1(3a) due out next week.
Robert
Yes, got an early trial, and confirmed the fix.
It was a particularly nasty bug that all users should be warned, given its impact, and difficulty tracking down.
4.0(4)SV1(3a) fixed a number of bugs, and should be upgraded to immediately.
