07-02-2019 11:37 PM
After factory defaulting Cisco9200L the switch stop at Message :bootable URL's in BOOT variable not found or exhausted
I believe the switch is now in ROMMON mode and needs to have boot file reinstalled ?Never done this before and would
really appreciate any help on how to reinstall boot image
09-24-2019 03:11 AM
Do you find anything ?
10-01-2019 07:04 AM
I'm facing the same with 9500
I'm not able to boot from usbflash0: and not able to copy bin file to flash: or bootflash: as they are ro (read only)
did you get the chance to solve it?
10-02-2019 07:10 PM
It is fixed for me:
- just download the .bin file to flash memory
- connect it to switch
- in Rommon type “emergency-install usbflash0:/cat9k......bin” most probably u have 2 usb ports one from front and one from back the front one is usbflash0 and back one usbflash1
- when the emergency install starts, it will run a bin recovery image from sda9, it will show the version of running ios recovery like 16.6.3, make sure u download the full ios bin file from same version or lower otherwise the emergency install will fail.
- when the process of emergency-install is completed u will get the switch running, after that the bin file is unpacked to flash:
- later u can download any bin file version and upgrade the ios.
- better to use USB flash memory rather than tftp as it might not connect to tftp after setting ip address/mask/gateway on rommom variables
I hope this will help.
Regards.
11-05-2019 10:47 AM
Thanks man!, This works for me.
Regards!
03-26-2020 09:12 AM
switch: emergency-install usbflash0:/cat9k_lite_iosxe.16.12.03.SPA.bin
Error: command 'emergency-install' not found. Use 'help' to list commands.
That's all I get. Anyone else?
04-10-2020 07:40 AM
I'm having that issue. Did you find a resolution?
04-10-2020 08:22 AM
05-06-2020 11:58 AM
07-30-2021 05:30 PM
That worked for me!! Thank you so much
03-19-2022 01:21 PM
I have a C9200 and after: factory-reset all I found myself in the same predicament. I downloaded the latest recommended Cisco .bin saved it to a USB Flash drive (fat32) and followed your advice. Worked like a charm. Thank you so much!
03-20-2022 11:20 AM
always a pleasure
07-25-2022 09:24 AM
Thank you very much, only your answer works
02-20-2024 06:34 AM
Life. Saver. Thank you so much.
04-11-2020 12:05 AM
