Whether Nexus3548 support Zero interrupt upgrade (or ISSU)?
Hello Everyone,
we need upgrade nexus3548,and we don't want to interrupt service. I didn't find some documents for disscussion about ISSU.
So i want to comfirm whether Nexus3584 support zero interrupt upgrade or ISSU ?
Please give me the documents or upgrade guide if it support. Thanks
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
josedelpino
Hi SYGY,
What version of NX-OS the switch currently is running and to which version you want to upgrade?
You can check the releases notes of the version that you want to upgrade for the procedure.
https://www.cisco.com/c/en/us/support/switches/nexus-3000-series-switches/products-release-notes-list.html
In this tool you can check is ISSU is supported:
https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/ISSUmatrix/index.html#cur=7.0(3)I7(7)&tar=9.2(4)
Thanks for your reply, nexus software release 6.0(2)A7(2)
Jaime G.
Hello SYGY,
Hope you are doing well.  After reviewing the discussion, I can see that you are running code: 6.0(2)A7(2) on your Nexus 3548.
Unfortunately upgrading from this code, as described in the article below:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3548/sw/release_notes/602_A7_1/n3k_rel_notes_6_0_2_a7_2.html
ISSU or Zero Interruption Upgrade is not supported and  "Install All is the only option that supports upgrade and downgrade between releases."
Therefore, upgrading your code will indeed require a reload of the switch.
HI Jaime :
Thanks for you reply.
I also find the documents link:
There is mentioned as below:
Upgrade Path to Cisco NX-OS Release 6.x
If a custom CoPP policy is applied after upgrading to Cisco NX-OS Release 6.0(2)A1(1) or later, and if the Nexus 3548 switch is downgraded to Cisco NX-OS Release 5.0, where changes to the CoPP policy are not permitted, the custom CoPP policy is retained and cannot be modified.
Note: copy r s and reload is not a supported method for an upgrade.
In addtion, i also find this info as below:
ISSUs are supported on the following platforms:
Cisco Nexus 3172PQ, 3172TQ, 3172PQ-XL, and 3172TQ-XL switches
Cisco Nexus 3132Q, 3132Q-X, and 3132Q-XL switches
Cisco Nexus 3064, 3064-X, and 3064-T switches
Cisco Nexus 3048 switches
Cisco Nexus 3016 switches
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/upgrade/7_x/b_Cisco_Nexus_3000_Series_NX_OS_Software_Upgrade_and_Downgrade_Release_7_x/b_Cisco_Nexus_3000_Series_NX_OS_Software_Upgrade_and_Downgrade_Release_7_x_newGuide_chapter_...
Is the nexus3548 older than other nexus3k device ?
Thanks & BR
