2800 IOS upgrade to 15.1(3)
JOHNY JOSEPH
The 2851 router has IOS 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(9)T7.
Current DRAM is 128MB & Flash is 64MB. Can i install IOS 15.1 verison without upgrading DRAM & flash.
regards,
Johny
clileikis
Level 7
Level 7
Hi Johny,
Assuming you're going to be using the same feature set, the 2851 will require an upgrade to 512 DRAM and 128 Flash in order to support the following image:  c2800nm-advipservicesk9-mz.151-3.T.bin
You can use the Cisco Feature Navigator to determine IOS image requirements: http://tools.cisco.com/ITDIT/CFN/
HTH,
Chris
Please rate helpful posts
clileikis
Level 7
Level 7
Hi Johny,
HTH,
Chris
