2921 pvm3-128 with cucm 7.1.2 compatability
ggittins35
i have the following issue and wanted to see if anyone out there has the gear layout.
CUCM is 7.1 .2
2921 pvdm3-128 ios 15,0 M
transcoding or mtp resources fails everytime invoked. regestered fine with cucm but according to ios gateway compatability matrix
the given hardware withy ios must be used with cucm 7.1.5 is this correct?
yuanwu
Hi, jorge
From the CUCM 7.x SRND, it should be supported.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/7x/media.html
Please attach the document you refer as the IOS gateway compatibility Matrix.
Rgds/Randy
Rob Huffman
Ho Jorge,
Support for the 2900's was actually added in CUCM 7.1(3)
Cisco 2901, 2911, 2921, and 2951
Interface Part Numbers
Onboard PVDM2 and PVDM3 DSPs
TDM Protocol or
Feature
Conferencing and transcoding
Minimum Cisco
IOS Software
Release
15.0.1M
Minimum Cisco
Unified
Communications
Manager Release
6.1.5, 7.1.3 or 8.0
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Cheers!
Rob
Following doc shd cover it (pl. bookmark it)
Cisco Unified Communications System Release Summary Matrix for IP Telephony
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html#wp1016708
DK
