12-10-2015 10:14 PM - edited 03-17-2019 05:11 AM
Hi guys,
I have a third-party PBX connected to a brand new 2921 with 4FXO. All the phones are registered to this PBX.
When I called the phone on the branches, I was supposed to dial "10", (wait till the call transfer from pbx to voip gateway ) and then dial the extension number (e.g. 6xxx, 7xxx). The voip gateway would transfer the call by the dial-peer over IP WAN.
After I replaced the voice gateway with 2921, the call failed. It sounded like the the call didn't transfer from pbx to 2921 after I dialed "10".
People from the branches could call my phone, and I couldn't call back.
Anyone met the situation like this? I'll be so glad the somebody could give me some hints to solve it.
version 15.4 ! hostname DuiVG-HK ! boot-start-marker boot-end-marker ! no ip domain lookup ip cef no ipv6 cef multilink bundle-name authenticated ! cts logging verbose ! voice-card 0 dspfarm dsp services dspfarm ! voice class codec 1 codec preference 1 g729r8 codec preference 2 g729br8 codec preference 3 g711ulaw ! ! license udi pid CISCO2921/K9 sn XXXXXXXXXXX hw-module pvdm 0/0 ! ! ! ! redundancy ! ! ! ! ! ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 ip address 192.168.0.252 255.255.255.0 duplex auto speed auto h323-gateway voip interface h323-gateway voip bind srcaddr 192.168.0.252 ! ip forward-protocol nd ! no ip http server no ip http secure-server ! ip route 0.0.0.0 0.0.0.0 192.168.0.250 ! snmp-server community netwoocin RO ! control-plane ! voice-port 0/0/0 cptone HK ! voice-port 0/0/1 cptone HK ! voice-port 0/0/2 cptone HK ! voice-port 0/0/3 cptone HK ! ! ! ! ! mgcp behavior rsip-range tgcp-only mgcp behavior comedia-role none mgcp behavior comedia-check-media-src disable mgcp behavior comedia-sdp-force disable ! mgcp profile default ! ! ! ! dial-peer voice 7 voip destination-pattern 7...$ session target ipv4:192.168.1.252 dtmf-relay h245-alphanumeric rtp-nte no vad ! dial-peer voice 6 voip destination-pattern 6...$ session target ipv4:192.168.2.252 dtmf-relay h245-alphanumeric rtp-nte no vad ! dial-peer voice 9 voip destination-pattern 9...$ session target ipv4:192.168.43.26 dtmf-relay h245-alphanumeric rtp-nte no vad ! dial-peer voice 81 pots destination-pattern 8..$ port 0/0/1 ! dial-peer voice 82 pots destination-pattern 8..$ port 0/0/2 ! dial-peer voice 83 pots destination-pattern 8..$ port 0/0/3 ! dial-peer voice 84 pots destination-pattern 8..$ port 0/0/0 ! ! ! ! gatekeeper shutdown ! ! |
12-11-2015 12:03 AM
Can you run a "debug voice ccapi inout" on the gateway to see if the call is even making it to the gateway.
Manish
12-13-2015 10:11 PM
Just for clarification please..
The current status is people at branches can call ( 8... ) while people at your branch cant call ( 6... ) and ( 7... ). Is that right ???
