3524XL Voice Vlan odd issue
wilson-danny
I have an odd one:
I'm setting up my CCIE lab, I get my CUCM and CME working no issues with IPC.
Then I get to the second portion, add a CME with a couple of 7940's, they won't get DHCP? So I try everything and finally remove the switchport voice Vlan command and then they start working.
CDP is enabled, I can ping the CME / DHCP server and it's not on a subdot1Q because I got frustrated and flattend the network . Checked spanning tree (Or what passed as spanning tree on this switch).. Check all sorts.
Any thoughts?
5 Replies 5
Tim Smith
Level 4
Level 4
So if you flattened it then you do not need a voice vlan.
If you want to set it up with a voice vlan, best to share your original config of router and switch.
You should have .1q trunk between rtr and sw. Are your dhcp scopes on the rtr? If not then you need helper addresses.
Config is slightly different on those older switches. I think you actually need to set the port as a trunk as well.
Cheers,
Tim
Hey Tim,
It was kind of obvious I wouldn't need voice vlan once I flattend it, I did try a trunk,
Config was just standard stuff I've done hundered's of times, just got the 3524XL today. I suppose I've been pampered in the work place with 3750's and Catk 6 / 4K's.
I had a 1760, Vlan DB on both (Vlan 100) subdot1Q fa0/0.100 (encapsulation dot1q 100) on the 1760 with an IP address. From this I could ping everywhere (PC etc.), the basic setup is switch and router with a router on stick config with DHCP set up. Nothing more, I tried switchport voice vlan 100 and still nothing more. Switchport voice vlan and dot1p is part of Cisco official documentation, after I flattend the network just testing I tried dot1p as well. Oh I also had an IP helper, used the native switch IP DHCP server command etc. etc.
If you set the port to access on the voice vlan and connect a PC do you get an IP on the voice network?
What CDP version are you running?
Luis A.
Danny,
3524 switches are nearly as old as me
You need to use the "vlan data" command to create vlans etc
Here is a wee sample
vlan data
vlan 11 name DATA
vlan 511 name VOIP
exit
conf t
hostname MY3524
enable secret CISCO
enable password CISCO
ip subnet-zero
udld enable
interface FastEthernet0/1
switchport trunk native vlan 11
switchport mode trunk
switchport voice vlan 511
switchport priority extend cos 0
spanning-tree portfast
no shut
interface FastEthernet0/2
no shut
The config/admin guide is at this link
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/swg/scg.html
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
+5....Spot on Alex. I have one of those oldies..and they only work with the trunk configs as you stated..
Please rate all useful posts
