3845 voice gateway card type configuration
HYEONJIN PARK
Hi~
I've a 3845 voice gateway
The device has 18 E1 port.
when I command
card type E1 1 0
card type E1 1 1
card type E1 2 0
card type E1 2 1
card type E1 3 0
card type E1 3 1
card type E1 4 0
card type E1 4 1
they are good status.
I check controller E1 1/0, 1/1, 1/0/0, 1/0/1
I check controller E1 2/0, 2/1, 2/0/0, 2/0/1
I check controller E1 3/0, 3/1, 3/0/0, 3/0/1
I check controller E1 4/0, 4/1, 4/0/0, 4/0/1
that also good
I install 2port e1 module on hwic slot 0
card type E1 0 0 is not confgurate.
I've checked sh inven, sh diag that was good.
controller E1 0/0 and 0/1 also check...
why the card type command is not insert?
Can I use the E1 ports??
I'm sorry.
This was not issue.
The card support only E1 type..
Thanks~
Aman Soi
can u share output of below commands
a. show diag
b. show inventory
c. show controllers E1
Which card u have inserted in HWIC slot of 3845 router and  snapshot of error u get while trying to configure?
regds,
aman
I'm sorry.
This was not issue.
Thanks~
