3905 ITL/CTL
rchaseling
Level 4
Level 4
Hi all,
My question is do they actual hold ITL/CTL certificates? I don't see any reference to it in the guide or mention of them on the phone web page
Need to migrate a bunch to a new cluster and wondering if these will just move across seamlessly without the need to cluster trusts or PhoneView (which doesn't support 3905 anyway)
Cheers
2 Accepted Solutions
b.winter
I think, the 3905s don't support the "security-by-default" feature, hence they don't have ITL / CTL installed.
So, you wouldn't need to care about them.
Jaime Valencia
Go to your CUCM, go to Unified Reporting, there's a phone feature list report, there should be an ITL and/or SBD option in the drop-down that will tell you which devices use it. Anything not listed does not use it.
java
if this helps, please rate
b.winter
Jaime Valencia
java
rchaseling
Level 4
Level 4
Looks like I'm good to go. Cheers guys!
