01-16-2008 08:53 AM - edited 03-15-2019 08:15 AM
the event log on my sub is filling up with 'transiet connection attempt' errors. I had a problem this morning where the pub/sub sql was not replication, as users were not able to un callfwd phones. I found Doc id 43581, and I stopped/started the CDL service on pub, and ran dblhelper to reinitialize. that has fixed the problems for now, but I am concerned about the sub errors. I recently applied SR6 also. any help as to what is causing these errors. thanks
01-16-2008 09:40 AM
Hi Pete,
Sounds like quite the day so far! Did the "transient connection attempt" errors subside after the replication issue was fixed? Can you look at the Mac address/addresses referenced in the errors to determine if it is just one phone or many?
Can you post one of the complete errors if this is still going on as these can be attributed to different issues. These are usually some sort of connectivity problem but with ATA's and VG248's they are config issues.
Let us know,
Rob
01-16-2008 10:16 AM
Rob,
thanks for your quick response. yes, the errors are still filling the event log. Here is a sample
Event Type: Error
Event Source: Cisco CallManager
Event Category: None
Event ID: 3
Date: 1/16/2008
Time: 12:06:52 PM
User: N/A
Computer: MBNPCCM2
Description:
Error: DeviceTransientConnection - Transient connection attempt.
Connecting Port: 2000
Device name [Optional].: SEP0019E74488CB
Device IP address.: 172.30.24.43
Device type.
[Optional]: 115
Reason Code [Optional].: 1
App ID: Cisco CallManager
Cluster ID: MBNPCCM1-Cluster
Node ID: 172.30.9.20
Explanation: A connection was established and immediately dropped before completing registration. Incomplete registration may indicate a device is rehoming in the middle of registration. The alarm could also indicate a device misconfiguration, database error, or an illegal/unknown device trying to attempt a connection.
Recommended Action: No action is required if this event was issued as a result of a normal device rehome..
Interesting thing is that it is always this MAC address, as well as two MAC addresses for ATA's
01-16-2008 10:35 AM
Hi Pete,
To eliminate part of the problem, for the ATA's you need to either configure or disable Line 2 on each ATA.
What is SEP0019E74488CB? Can you look into it and perhaps remove it until you can track it down and look for the actual problem.
Hope this helps!
Rob
PS: I also remember one time where we had ATA's configured but not actually connected where we got a bunch of these errors.
