06-26-2013 02:15 AM - edited 03-16-2019 06:05 PM
This is a new install of CUCM9.1 with SIP trunks on a CUBE (Version 15.2(4)M2). The CUBE is behind an ASA and a PIX. The ASA is the corporate perimeter and the PIX is the client site.
Outbound I get a 403 forbidden then fast busy. We are sending the call setup to the ITSP fine.
Inbound the call rings my extension but when I answer the PSTN still hears ringing, I hear dead air - so I think the response to the invite is not being sent to the ITSP.
I have my concerns that this is down to the ASA/PIX config but would appreciate a sanity check.
I've attached a "debug ccapi mess" & "debug voice ccapi inout"
thanks
PC.
Solved! Go to Solution.
06-26-2013 10:20 AM
Paul,
Looking at the debug..the cause code is "Cause Value=57" This refers to a bearer capabilities issue. From your INVITE you are not offering any media capabilites to the ITSP..
I suggest you enable early offer on either the globall level or on your dial-peers facing ITSP
voice service voip
sip
early-offer forced
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
06-26-2013 10:20 AM
Paul,
voice service voip
sip
early-offer forced
06-27-2013 01:33 PM
As always with SIP, you hit the nail on the head.
The issue was resolved by adding the "early-offer forced" but also by the customers security team sorting out a double NAT - the ITSP trunk negotiates an ASA and then a PIX so there were some fixup & inspect issues involved also.
Thanks for taking the time to assist
06-27-2013 01:37 PM
Glad to help and thanks for rating and compliments
