6921, Dial on handset pickup error
Some users got used to dial in following manner - they enter number on dialpad and then pickup headset. After 7911 phones been replaced with 6921 this technique doesn't work anymore. After picking up headset phone complains about reaching maximum nuber of calls per line, though there was not active calls at all.
CUCM System version: 7.1.4.10000-4 Unrestricted
Phone load SCCP 9.2.1.0
Any ideas?
Rob Huffman
Hi there,
It sounds like this bug;
CSCtq45335 - on-hook dialing failed when maximum numbers call is set to 2
Description
Symptom:
The 6921/6941/696/6945(SCCP 9-2-1-0) cannot make a call  with off-hook.
the massage "Unable to create a call; the maximum number of calls for this line has been reached..."  popped up
reproduce steps:
1. Dialed number with on-hook.
2. Off hook
3. can not make a call, I can see the dial-tone.
Conditions:
Only occurred on 6921/6941/696/6945 SCCP 9-2-1-0
Workaround:
In  CUCM 8.6 and later, configuring maximum number of calls to 3 under  phone's line page can avoid this issue. Prior to CUCM 8.6 there is no  workaround available.
Details
First Found in:                          (1)
9.2(1)
Status:
Fixed
Last Modified:
Dec 10,2012
Fixed in:                          (1)
9.2(1)SR1
Product:
Cisco Unified IP Phone 6900 Series
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
Rob Huffman
Hi there,
Description
Symptom:
reproduce steps:
2. Off hook
Conditions:
Workaround:
Details
First Found in:                          (1)
9.2(1)
Status:
Fixed
Last Modified:
Dec 10,2012
Fixed in:                          (1)
9.2(1)SR1
Product:
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
-The Clash
Thanks.
One of users claims what he was using this technique for several months untill it suddenly stopped working.
A buggy bug?
Page is unavailable.
Can we get the bug information re-published on the website? Thanks
