IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5822 Views
  • 14 replies
Hi, We have configured Hotline between 2 extensions. Ex: from line number 8355, if they lift the receiver it will ring on another extension in 8356 and similarly from line number 8356, if they lift the receiver it will ring on 8355 as hotline. Hotlin...
We have CUCM 11.5 that is connected by sip trunk to a CUCME in a remote office. the Sip trunk is up and the remote office can call the head office but the head office can't call the remote office. i don't have access to the CUCME in the remote office...
maccollins by Level 1
  • 1965 Views
  • 10 replies
Hello,I am trying to make a request with  Postman but I always receive an 599, the same request is working with SOAPUI. Can someone help me with the configuration of postman to make it work? I already read the blog "https://info.stack8.com/blog/cisco...
jolfi2009 by Level 1
  • 473 Views
  • 0 replies
I have users that have speed dial numbers programmed. When you press down on the Navigation ring, you see the speed dial number. However, the list stops at 6. I made a test phone button template with 4 lines & 32 speed dials. Applied that to a phone ...
Resolved! Vg204XM FAX
Hi, I am wondering if someone can answer my query...if I have brand new vg204xm gateway and if I plug-in analog phone to one of the ports in the back (ports 0/0 to 0/3) should I get fast busy or dial tone or nothing (dead air)? Thanks
G3261 by Level 4
  • 705 Views
  • 2 replies
