6921 ip phones not registered
mohammedobaid
Dear all,
We changed ip schema of all buildings but in one building the 6921 ip phones are not getting registered
when we place a different model on the same port like 7945, 7965 the phone gets registered and starts working
only 6921 ip phones are not working
these 6921 ip phone take ip, vlan tftp and all setting but still not getting registered
11 Replies 11
Leo Laohoo
Maybe erase the config of the phone?
I erased the config and also did factory reset but still its not getting registered
What does it show in Status Message
Also check if ports are allowed between phone sub net and CUCM
Can't download configuration file XMLdefault.cnf.xml.sgn from 10.200.
tftp error: download xmldefault fail
CTL sep(mac phone).tlv updated fail
tftp error: CTL sep(mac phone).tlv fail
This Indicates that TFTP ports are blocked between this subnet and CUCM.
Check in the firewall for the same.
Please rate and mark correct<<<<!!
Haris
no firewall and no tftp ports are blocked
Does not look like any firewall issue as other phones are getting registered. It looks like the server is missing the default config file "XMLdefault.cnf.xml.sgn" or not able to locate in the server.
You may try one thing...
1. Create 6921 phone manually with MAC address which creates this phone specific configuration file.
2. Try to register now. If it gets registered, then this is the problem with only Auto registered 6921 phones not able to locate default config file "XMLdefault.cnf.xml.sgn".
Ashok.
With best regards...
Ashok
this phone is manually done but still it is unable to download conf files
and not getting register
HARIS_HUSSAIN
Try Factory reset of one phone .
What does it show in the status messages. ( Settings > Status> Status Message )
Thansk
Haris
salmandhunna1
remove the netwrork cable and plug in again , i faced similar issue few days back :)
