6941 firmware 9.3(3) - Web access disabled - CME
Joseph Chambers
CME 8.6
under telephony service
will
service phone webAccess 0
re-enable it?
Is there a DST issue with this too?
Chris Deren
Yes, it will, you will need to reset the phone after this for it to take affect.
HTH,
Chris
testeven
8.x firmware and lower had the web sever enabled by default, but enabling webAccess on IP phones is required on 9.x+ firmware for services like Extension Mobility which require the Authentication URL.
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
