6941 issue with 2960S
TJ Kelly
We just upgraded to 2960S, POE, 1Gb ports.  The 6941 phones (100mb port speed) work fine by themselves, but when you plug a computer into the back of the phone the speed is awful.  I can plug the same computer directly into the switch and have no speed issues.   Other 7900 series phones (gb speed) work fine.  The switches are running 12.2(58) SE2 and the phones are running sccp69xx.9-3-1-3
Has anyone else seen this behavior?
TJ
7 Replies 7
amarjit4321
Hi Kelly,
Have you tried by changing the duplex of the switch port.
Amarjit Das
try upgrading the phone to latest cmterm-69xx-sccp.9-3-3-2-sr1.cop.sgn on one of 6941 phone and check.
regds,
aman
Chris Deren
When you say speed is awful, what do you mean?
Abviously 100mb phone will be a bottleneck on 1gb link.
Chris
TJ Kelly
I just upgraded to the newest firmware (cmterm-69xx-sccp.9-3-3-2-sr1) on the phone.  No change in the speed.  The setup was previously on an Avaya (100mb port) and plugged into a 100MB Cisco 2950 Switch and the user was able to pull up the file immediately.  The user attempted to pull up a GIS drawing (2MB) and it took approx 15 secs.  We bypassed the phone and tried the same file and it was almost immediate.  Another user on a 9971 phone was able to pull up the file immediately also.
TJ
Can you post "sh interface gix/x"  where x/x is the port in question?
Chris
Hope I am wrong here, but have you tried to test your link with TDR?  Try this:
1.  Command:  test cable tdr interface ;
2.  Wait for approximately 5 to 7 seconds for the test to run;
3.  Command:  sh cable tdr interface ; and
4.  Post the output to #3.
NOTE:  This is not related to your phone issue but this could potentially cause issue to your switch as a whole.  What I am saying is try avoid using 12.2(58)SE and later IOS.  This version is notorious for various CPU bugs which could not be fixed.  Try 15.0(2)SE4 instead.
TJ Kelly
Here is the interface status......
GigabitEthernet1/0/14 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 04da.d24a.868e (bia 04da.d24a.868e)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:39, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 24000 bits/sec, 33 packets/sec
     10969 packets input, 1274572 bytes, 0 no buffer
     Received 2711 broadcasts (2675 multicasts)
     0 watchdog, 2675 multicast, 0 pause input
     2259191 packets output, 223531097 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     1335 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
