6945G versus the 7945G
Dominic Ellis
I've been looking at the 6945G phones. We want Gigabit to the desks,
and there is quite a saving as compared to the 7945G phones.
Does anyone know what differences there are between these and the 7945G,
Are there feartures or services not available on 6945G - aside of the colour screen.
Best Regards
Dominic
paolo bevilacqua
There are many diffrences mainly related to the maturity and stability of software the 7945. If you want a 1st class, truly standard and reliable solution, go for it. Otherwise be adivce that you may find more bugs and limitations on all the 69xx.
Thanks Paolo,
It was the limitations of the 6945 that I was looking for.
Specifics rather that overview.
Dominic
There are quite many, sorry if I'm unable to produce a list on simple request.
Thanks Paolo - even just the major ones would be helpful.
I wasn't expecting someone to produce a list.
I can't really go back to management and say - yes there are limitions.
They will immediately say so what are those limitations?
That's why I posted the question.
But I do appreciate your reply.
Best Regards
Dominic
