7841 firmware with CME 10.5
AT
I am using firmware 11, but seems buggy.  Is 10.3 recommended for use with CME10.5?
AT
Deepak Rawat
If you will check the CME 10.5 Compatibility Matrix,the suggested FW load is 10.1(1)SR1 at the time when CME 10.5 was released, however you can definitely use 10.3(1) since that is the latest on 10.x FW load as of now:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme105spc.html
Deepak
Thank you for the info.
