11-28-2006 03:50 PM - edited 03-14-2019 06:59 PM
Dear fellows, does anybody tried to register an 7906 with SRST??? in the release notice they said that is supported, but it is not true, i tested with srst3.3, and 4.0, does anybody can help me?
I have a 4.2(3)CALLMANAGER and srst is in a 2851 with 12.4T
Could you help me?
Thank you very much
12-02-2006 07:39 AM
7906 is supported in CME in IOS Version 12.4(4)XC, so I assume that this is the case for SRST too.
mat
12-04-2006 01:14 AM
I'm assuming you've got the Device Pool configured for the 7906 and the Device Pool has the reference to the SRST?
12-04-2006 04:09 AM
Maybe it is only a firmware problem.
check if in your flash the related file is stored!
regards
