7961 Keeps rebooting during factory reset
smolz
Level 4
Level 4
I have a 7961 that I did a factory reset command on, I see it reboot and show a screen with upgrading and term61.default
The phone displays that for a few seconds and then reboots and after 30 sec or so displays the same thing.
Any ideas on how to fix this?
nitsinha
Level 4
Level 4
Are you trying to register it to the CUCM or CUCME? Check whether the phone has obtained an IP address and TFTP server address. Also make sure the CUCM/CUCME has the firmware files that the phone is requesting for.
Nitesh
PS:Pl rate helpful posts
nitsinha
Level 4
Level 4
Nitesh
