01-27-2013 11:09 AM - edited 03-16-2019 03:23 PM
Hi all,
I'm trying to configure a Cisco 7975 for SIP.
I upgraded the phone to SIP75.9-3-1SR-1S and configured the xml.
The phone registers but there is a problem with the lines: on L1&L2, I see a phone icon with an X next to it.
The lines don't register..
Here is the config for L1:
<line button="1">
<featureID>9</featureID>
<featureLabel>100</featureLabel>
<name>Auth_ID</name>
<displayName>100</displayName>
<contact>100</contact>
<proxy>SIP_Provider_IP</proxy>
<port>5060</port>
<autoAnswer>
<autoAnswerEnabled>2</autoAnswerEnabled>
</autoAnswer>
<callWaiting>3</callWaiting>
<authName>Auth_ID</authName>
<authPassword>Password</authPassword>
<sharedLine>false</sharedLine>
<messageWaitingLampPolicy>1</messageWaitingLampPolicy>
<messagesNumber>*0</messagesNumber>
<ringSettingIdle>4</ringSettingIdle>
<ringSettingActive>5</ringSettingActive>
<forwardCallInfoDisplay>
<callerName>true</callerName>
<callerNumber>false</callerNumber>
<redirectedNumber>false</redirectedNumber>
<dialedNumber>true</dialedNumber>
</forwardCallInfoDisplay>
</line>
Do you have any ideas?
Has anyone had this issue before?
Thanks a lot.
Best regards
01-27-2013 02:13 PM
Hi Stephan,
Where you are adding this phone. I mean on CUCME Or CUCM and on which verison.
Shakti
01-27-2013 10:58 PM
Hi Shakti,
thanks for the reply.
I'm adding it directly to a SIP Provider.
Thanks.
01-29-2013 07:29 AM
any ideas?
Thanks.
01-30-2013 09:35 PM
Here are the reasons why you could be seeing X...
Hope this helps!
Karthik
02-04-2013 01:16 AM
Hi Karthik,
thanks for the link.
I haven't managed to solve the issue.
I tried also with a different firmware but the phone doesn't register.
I also configured the phone with a public IP but no luck. There is no FW between the phone and the SIP provider.
Any ideas what I should check?
Thanks.
Best regards
02-08-2013 02:56 AM
Hi Karthik,
still no luck.
any ideas?
Thanks.
