11-09-2012 04:43 AM - edited 03-16-2019 02:06 PM
Hi!
I would like to ask how do I know the different lines in different SIP servers to register?
/tftp_root/SEP010203040506.cnf.xml :
<callManagerGroup>
<name>Default</name>
<tftpDefault>true</tftpDefault>
<members>
<member priority="0">
<callManager>
<name>10.0.0.1</name>
<description>10.0.0.1</description>
<ports>
<ethernetPhonePort>2000</ethernetPhonePort>
<sipPort>5060</sipPort>
<securedSipPort>5061</securedSipPort>
<mgcpPorts>
<listen>2427</listen>
<keepAlive>2428</keepAlive>
</mgcpPorts>
</ports>
<processNodeName>10.0.0.1</processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
<sipProxies>
<backupProxy>USECALLMANAGER</backupProxy>
<backupProxyPort>5060</backupProxyPort>
<emergencyProxy>USECALLMANAGER</emergencyProxy>
<emergencyProxyPort>5060</emergencyProxyPort>
<outboundProxy>USECALLMANAGER</outboundProxy>
<outboundProxyPort>5060</outboundProxyPort>
<registerWithProxy>true</registerWithProxy>
</sipProxies>
In the sipLines session only "USECALLMANAGER" given IP address is not accepted:
<sipLines>
<line button="1" lineIndex="1">
<featureID>9</featureID>
<featureLabel>Office 10 (1237)</featureLabel>
<proxy>USECALLMANAGER</proxy>
<port>5060</port>
<line button="2" lineIndex="2">
<featureLabel>Another Office 14</featureLabel>
<proxy>USECALLMANAGER</proxy> <= but this is another SIP (asterisk) server with another IP
<port>5060</port>
Thank's!
11-09-2012 05:39 AM
Cisco does not support or document use of the phones with third party PBX. You can try that on sites like voip-info.org
11-10-2012 01:08 AM
Thanks for your response!
I would rather ask, why can not I specify a separate SIPproxy IP address for the SIPline's?
What happens when the telephone (sip)lines must be registered to another different CallManager's?
A cheaper device (like the Linksys SPAxxx) is not a problem. Each Siplines (Ext1..4) can i insert separate SIP proxy IP addresses.
Thank you!
11-10-2012 02:59 AM
As above, Cisco makes these telephone for CM and CME, not for any other use.
11-10-2012 08:51 AM
Hi Paolo,
OK, let's say I am using Cisco CM or CME. I have two Cisco CM running at two different locations. Am I able to use both Cisco CM at once (so the phone is able to register to both whether I am using SCCP or SIP firmware) or the only way to have a remote extension from the second CM is to use a trunk between the two CM and forward my calls through the trunk?
Frank
11-10-2012 11:02 AM
First of all, normally most Cisco phones uses the SCCP protocol that is superior to SIP in terms of features and ease of administration. This protcol always register to a single system.
Then you would have the two CM systems connected by a so called inter-cluster trunk, that would avoid the complication an unpracticality of having a phone registerd to two systems.
