8800 and 7800 series IP Phone firmware download link
We download the CME complete set firmware in URL- https://software.cisco.com/download/release.html?mdfid=277641082&flowid=77925&softwareid=282786567&release=10.5&relind=AVAILABLE&rellifecycle=&reltype=latest
In that we are not able to find 8800 and 7800 IP Phone firmware, Please advice the URL link to download CME IP Phone firmware for 7800 and 8800 model
Rob Huffman
Hi there,
For CME you will be using the .zip files;
For 88xx the path is;
Session Initiation Protocol (SIP) Software-10.3(1)
And look for;
cmterm-88xx.10-3-1-20.zip
And for 78xx the path is;
And look for;
cmterm-78xx.10-3-1-12.zip
Cheers!
Rob
Please try this link:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
It gives you the firmware that you should use based on your IOS version. find it then download the files.
Thanks Mohammed, the link for Compatibility Matrix. I need download link for 7800 and 8800 model ip phones.
You have to check the matrix first. You did not give us the version of your IOS or CME. maybe you need to upgrade first.
However, after determining the required files you can download it from here:
https://software.cisco.com/download/release.html?mdfid=277641082&softwareid=282786567&release=10.5&relind=AVAILABLE&rellifecycle=&reltype=latest
Rob Huffman
Hi there,
And look for;
And look for;
Cheers!
Rob
