MCS 7800 series server with call manager 5.1 integrated with UCS 220 server with cucm 10.1
heba00001
i have old cisco MCS 7800 series server with call manager 5.1  , i need to integrated with UCS 220 server with cucm 10.1 , so if any one could help me,  they could be integrated or no ??
thank you ,
regards
heba
Aman Soi
Hi Heba,
you can either use BAT or can upgrade call manager from 5 to 7 on MCS provided MCS hardware supports.Then build UCS on 7 in offline restore backup from MCS and then, further migrate using PCD but is time consuming.
regds,
aman
Manish Gogna
Hi Heba,
Cucm 10.x is not supported on mcs servers, so your mgs server can not be integrated with your 10.x cluster on ucs.
Manish
j.huizinga
Level 6
Level 6
what do you mean?
Integrate => CM 5.1 and CM 10.1 can communicate with each other? Or do you want to upgrade 5.1 to 10.1?
JH
