04-20-2017 10:35 AM - edited 03-17-2019 10:07 AM
I am using an 8811 and when I place a call on park , the Parked call stays on the 8811 (phone). I can pick the call using the parked extension so it looks like the feature works however I have never seen the Parked call stay on the Phone that parked it. CUCM is version 10.5.
Any thoughyts
Solved! Go to Solution.
04-20-2017 10:43 AM
Hi Mike,
It sounds like this bug/enhancement;
04-20-2017 10:43 AM
Hi Mike,
04-20-2017 11:13 AM
+5 Rob
Also see
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCux68138/?reffering_site=dumpcr
JB
04-20-2017 11:17 AM
Thank You for taking time to reply...
04-20-2017 11:19 AM
Happy to help
04-20-2017 11:14 AM
Thanks Rob.. I was just going thru the release notes to see if it was an bug or working as designed.
Thanks for answering so fast.
Mike
08-22-2019 10:10 AM
Hello, the bugs CSCux68138 was recently listed as resolved, but we still see the issue with CUCM 12.5(1), & 8800 firmware 12.5(1). Has anyone been able to confirm if this is actually fixed and parked calls no longer consume the slot on the phone?
05-26-2020 11:08 AM - edited 05-26-2020 11:10 AM
Hello @Jitender Bhandari ,
I see this bug (CSCuy32083) has been marked as resolved/closed as resolved with the 12.8.1.1.438 firmware. I've just tested the scenario out again with the new firmware on CUCM 12.5.1.11900 and we see the same results as we've seen since CUCM 11.x w/ 8800 series phones.
Is there a setting or feature that needs to be enabled in the new firmware to resolve the issue?
