8811 Compatibility
We're looking at getting a number of 8811 phones.
How do I tell if they are compatible with CUCM System version: 11.0.1.21900-10?
In the docs I see:
Table 5. Cisco Unified IP Phone 8800 Series Device TypeDevice Release Unified CM 12.0(1)Unified CM 11.5(1)Unified CM 11.0(1)Unified CM 10.5(2)
8811, 8841, 8845, 8851, 8851NR, 8861, 8865, and 8865NR
12.5(1)SR1
cmterm-devicepack12.0.1
Feb 4, 2019
cmterm-devicepack11.5.1
Jan 24, 2019
Currently Not Available
cmterm-devicepack10.5.2
Jan 24, 2019
Which makes me think it is not compatible, even though I can add 8811s in CUCM.
Jaime Valencia
Datasheet says 11.0 and later, if you're running the latest SU for 11.0 or installed the latest DevPack at some point, and you see the phone model in the drop-down, then it's supported in your version.
java
if this helps, please rate
Jaime Valencia
java
