8811 phones on CME 11.6 - Phone Only Dials 1 Digit - Auto Reg
steigja
Level 3
Level 3
Hello All,
   I'am having an issue with a CME router that is on version 11.6 and adding two 8811 phones to the configuration.  Auto registration was previously enabled.  I was able to get the phone to auto register successfully.  However when we dial it is only sending one digit at a time.  The "no digit collect kpml" is configured on the voice register pool.
   So I don't know how to fix the issue.  The 8811's are running sip88xx.11-0-1-11.  There are a number of other 8811's that are running fine, its just now we are trying to add 2 more brand new.  When I disable auto reg the phone sits in "unprovisioned".  I know this is all end of life but has anyone seen this issue before?  Thanks!
Jason
What if you configure the phones in CME so that they don’t need to use auto registration. Does it work then?
Response Signature
Roger,
No It doesn't work if I disable auto reg. The 8811 sits there in status “unprovisioned”. Thanks
Jason
Can you please share the configuration from CME for a non working and a working phone?
Response Signature
Roger,
   I appreciate it!  The working phone is pool 6 below, its no different then the non working phone which is pool 16.  It does however look like it was previously configured for auto registration since it has the password and username in there.  All of the phones are configured as voice register pools.
--working phone--
voice register pool 6
busy-trigger-per-button 2
id mac 5488.DECE.54E7
type 8811
number 1 dn 6
template 1
dtmf-relay rtp-nte sip-notify
username cshare6 password 8811
codec g711ulaw
non working phone
voice register pool 16
id mac 94D4.692B.AEAC
type 8811
number 1 dn 24
template 1
username auto16 password 8811
codec g711ulaw
no vad
