8831 conference phone - No join softkey in connected state
majeed002
In 8831 conference phone, I have two connected calls - 1 on hold and another connected.  I want to create conference using these calls.  In other model phones, I can use join/conference softkey to convert these individual calls in to a conference call.  But in 8831 conference phone, there is no join softkey to merge the calls.  Also, when I press conference button, it gives a dial-tone instead of showing the list of active calls.
I could see that the softkey template has no impact on 8831 softkey configuration.  Is there any way to achieve this.
Can you check if  you have below parameter is set to True
CUCM - Service Parameters - Advanced Ad Hoc Conference Enabled
Rest is the same as suggested by Nadeem:
Join  --  From a connected call,  press  Conference and then  press  Calls  to view a call  list for join.
And I want to add that this feature will not be available if you have two on-hold calls.You should have one active call at least.
Deepak
6 Replies 6
Deepak Mehta
One thing that i am aware of is 8831 doesn't support join softkey.That said , i haven't tested any other way of getting around this.thanks
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/9_3_3/english/adminguide/CS38_BK_A8C4AC51_00_adminguide-8831/CS38_BK_A8C4AC51_00_adminguide-8831_chapter_0101.html#CS38_TP_SA33519E_00
Nadeem Ahmed
Hello Majeed
8831 does not support Join as a softkey feature, check the link below
 http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/9_3_3/english/adminguide/CS38_BK_A8C4AC51_00_adminguide-8831/CS38_BK_A8C4AC51_00_adminguide-8831_chapter_0101.html#CS38_TK_S8F9C89F_00
Please check the below how to accomplish your requirement
 http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/9_3_3/english/quick_start/quick_start_8831.pdf
Join: From a connected call, press Conference and then press Calls to view a call list for join.
Br,
Nadeem Ahmed
Br, Nadeem Please rate all useful post.
Thanks Nadeem.  Yes, I did gone through this document.  As mentioned in my original post, when I press the conference button with two active calls in 8831 (one on hold & one on connected state),  I am getting a dial-tone instead of showing the list of active calls.  Why is it not showing the list of active calls.
Deepak
Rob Huffman
Hi Majeed,
In addition to the great info from my friends Deepak M., Nadeem & Deepak R. you may be hitting this bug on the 8831. It details a similar call setup as to what you are attempting and relates to firmware 10-3-1 and 9-3-2;
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCug20247
Can't conf another conference via Calls softkey
CSCug20247
Symptom:
Unable to complete a conference call on an 8831.
Conditions:
Reproduce steps:
1. Make CP-8831 phone has a 3-way conference.
2. Place a new call to CP-8831, CP-8831 answer.
3. Now CP-8831 screen focus on the new call.
4. Press the conference softkey.
5. Press the calls softkey.
6. Highlight the 3-way conference and press conference softkey.
7. Conference can't complete.
Workaround:
Joining a basic existing call into conference works well. Consult conference call feature works well as well.
hello Team,
Can I actually update the Soft key template for 8831 phones ?
Seems Soft Key Template has no effect on 8831 phones and seems is of no Use, is this correct statement ?
