01-29-2016 07:16 AM - edited 03-17-2019 05:40 AM
I upgraded a CUCME to 10.5 to allow 8831s to be used on it.
I have run into a software problem with the phones, it that as I was doing it remotely I didn't see the label on the botom of the phones listing the minimum software revision so I loaded and served out 9.3.3.5
I now need to re-upgrde the phones to 10.3.1 to get them working.
I editted the lines on the CUCME but the phones won't download the files. Do I need to delete the VOICE REGISTERGLOBAL lines and re-insert them on the CUCME to get the phones to download the files that are available via TFTP.
voice register pool-type 8831
xml-config maxNumCalls 2
xml-config busyTrigger 1
xml-config custom sshAccess 0
phoneload-support
num-lines 2
description Cisco SIP Phone 8831.
reference-pooltype 6921
voice register global
mode cme
source-address 172.21.138.10 port 5060
max-dn 10
max-pool 10
load 8831 sip8831.9-3-3-TO-10-3-1.loads
authenticate register
tftp-path flash:
file text
create profile sync 0060183722218222
voice register dn 7
number 2390
name Board Room
label Board Room 2390
voice register dn 8
number 2391
name Balvennie Room
label Balvennie Room 2391
voice register dn 9
number 2392
name Glefiddich Room
label Glenfiddich Room 2392
voice register pool 7
busy-trigger-per-button 1
id mac AC44.F214.3336
type 8831
number 1 dn 7
dtmf-relay sip-kpml
codec g711ulaw
voice register pool 8
id mac AC44.F213.EE11
type 8831
number 1 dn 8
dtmf-relay sip-kpml
codec g711ulaw
voice register pool 9
id mac AC44.F213.FC2E
type 8831
number 1 dn 9
dtmf-relay sip-kpml
codec g711ulaw
Solved! Go to Solution.
01-29-2016 07:26 AM
https://supportforums.cisco.com/discussion/12749351/cisco-8831-firmware-upgrade
Deepak
01-29-2016 08:52 AM
Hi Steve,
I believe you would need;
Router(config-register-global;)# create profile
From;
Cheers!
Rob
01-29-2016 10:11 AM
Hi Steve,
Best of luck with this change! Just to verify you downloaded the "v2" version of the zip files;
cmterm-8831-sip.9-3-3-TO-10-3-1-v2.zip
Cheers!
Rob
01-29-2016 10:24 AM
Yeah I know that is a CM thread. The idea was to give you the information about the interim upgrade which is required in order to reach 10-3-1-16.
You will need to use the load command with exact name of FW under voice register global, rest remains the same as you normally do for FW upgrade
Deepak
01-29-2016 07:26 AM
Deepak
01-29-2016 07:36 AM
That thread is for a Callmanager, I have a Callmanager Express. I understand the firmware upgrade needs the interim version. I'm confused about the cli commands on the Callmanager Express
01-29-2016 10:24 AM
Deepak
01-29-2016 08:52 AM
Hi Steve,
From;
Cheers!
Rob
01-29-2016 09:13 AM
Thanks Rob,
That's the conformation that I was looking for. People were suggesting create config files in the Telephony system part of the configuration, but that didn't work.
I'll be trying again on Monday, wish me luck.
01-29-2016 10:11 AM
Hi Steve,
Cheers!
Rob
