8831 on a CUCME
steven.wilson
I upgraded a CUCME to 10.5 to allow 8831s to be used on it.
I have run into a software problem with the phones, it that as I was doing it remotely I didn't see the label on the botom of the phones listing the minimum software revision so I loaded and served out 9.3.3.5
I now need to re-upgrde the phones to 10.3.1 to get them working.
I editted the lines on the CUCME but the phones won't download the files. Do I need to delete the VOICE REGISTERGLOBAL lines and re-insert them on the CUCME to get the phones to download the files that are available via TFTP.
voice register pool-type  8831
 xml-config maxNumCalls 2
 xml-config busyTrigger 1
 xml-config custom sshAccess 0
 phoneload-support
 num-lines 2
 description Cisco SIP Phone 8831.
 reference-pooltype 6921
voice register global
 mode  cme
 source-address 172.21.138.10 port 5060
 max-dn 10
 max-pool 10
 load 8831 sip8831.9-3-3-TO-10-3-1.loads
 authenticate register
 tftp-path flash:
 file text
 create profile sync 0060183722218222
voice register dn  7
 number 2390
 name Board Room
 label Board Room 2390
voice register dn  8
 number 2391
 name Balvennie Room
 label Balvennie Room 2391
voice register dn  9
 number 2392
 name Glefiddich Room
 label Glenfiddich Room 2392
voice register pool  7
 busy-trigger-per-button 1
 id mac AC44.F214.3336
 type 8831
 number 1 dn 7
 dtmf-relay sip-kpml
 codec g711ulaw
voice register pool  8
 id mac AC44.F213.EE11
 type 8831
 number 1 dn 8
 dtmf-relay sip-kpml
 codec g711ulaw
voice register pool  9
 id mac AC44.F213.FC2E
 type 8831
 number 1 dn 9
 dtmf-relay sip-kpml
 codec g711ulaw
4 Accepted Solutions
Deepak Rawat
https://supportforums.cisco.com/discussion/12749351/cisco-8831-firmware-upgrade
Deepak
Rob Huffman
Hi Steve,
I believe you would need;
Router(config-register-global;)# create profile
From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmefiles.html#pgfId-1023156
Cheers!
Rob
Rob Huffman
Hi Steve,
Best of luck with this change! Just to verify you downloaded the "v2" version of the zip files;
cmterm-8831-sip.9-3-3-TO-10-3-1-v2.zip
Cheers!
Rob
Yeah I know that is a CM thread. The idea was to give you the information about the interim upgrade which is required in order to reach 10-3-1-16.
You will need to use the load command with exact name of FW under voice register global, rest remains the same as you normally do for FW upgrade
Deepak
6 Replies 6
Deepak Rawat
Deepak
That thread is for a Callmanager, I have a Callmanager Express. I understand the firmware upgrade needs the interim version. I'm confused about the cli commands on the Callmanager Express
Deepak
Rob Huffman
Hi Steve,
From;
Cheers!
Rob
Thanks Rob,
That's the conformation that I was looking for. People were suggesting create config files in the Telephony system part of the configuration, but that didn't work.
I'll be trying again on Monday, wish me luck.
Rob Huffman
Hi Steve,
Cheers!
Rob
