07-18-2022 08:25 AM
Good day,
I just received some 8832NR phones. I tried to install a couple but I'm getting some errors. I installed the phone like i would any other. The errors im getting on the phone itself is Telephone service unavailable, and the phone is stuck in a "phone is registering" state. On Cucm it shows rejected. The phone is auto registering with DHCP, It retrieves all the IPV4 information, plus the TFTP servers. The active load is the latest at 14.1, My CUCM is currently 12.5 SU6. I have tried deleting the phone from CUCM and re-installed it. All certs are correct, and i have it registering to the local SUB.
Any assistance would be greatly appreciated.
Solved! Go to Solution.
07-18-2022 11:15 AM
Got it.
So when registering the phone i selected the 8832 NR template. For some reason that was causing an mismatch error in CUCM and therefore it was rejected. I changed the template to universal and it worked. Not entirely sure why that worked but it did.
07-18-2022 08:32 AM
Kindly check the below
- firmware version. Cucm must have the minimum firmware mentioned on the phone cartoon box.
- if it was used with another call manger,Reset the phone and see.
07-18-2022 08:42 AM
Yeah, Tried factory resetting the phone a couple times. firmware is latest version from Cisco. Just updated to SU6. Do i have to have a rollback firmware to make this work? Like an older version then try to upgrade it?
07-18-2022 08:48 AM
What you see on phone status messages ?
07-18-2022 09:33 AM
just telephone services unavailable and then phone is registering. but on CUCM it shows registration status as rejected
07-18-2022 09:40 AM
From phone settings you can see the status messages.
what exactly you see on the status messages ??
07-18-2022 09:45 AM
oh i understand i apologize. im not at the phone currently but ill get you that info soon
07-18-2022 11:15 AM
Got it.
