02-01-2012 06:46 AM - edited 03-16-2019 09:20 AM
Where can I download the languages files for 8941 in of CME 9.0
I already browsed in the cisco download, but i've found only the locale installer for CUCM.
http://www.cisco.com/cisco/software/type.html?mdfid=283095470&flowid=24541
Any help please.
Antra
Solved! Go to Solution.
02-01-2012 06:51 AM
Hi Antra,
Follow this path
Unified Communications Manager Express Individual File Set-9.0
cme-9.0-locale.rar | |
Release Date: 22/APR/2011 | |
Locale files for CME 9.0 | |
Size: 34443.71 KB (35270349 bytes) |
Cheers!
Rob
02-01-2012 06:51 AM
Hi Antra,
Follow this path
Cheers!
Rob
02-01-2012 10:29 PM
thank you Rob.
02-01-2012 11:52 PM
I've dowloaded the file, but my problem i can't find or i don't know the file for the SCCP, for French Language
From documents, i' should have a file named : gh-sccp.jar for the 8941, but I don't see it in the French file.
The file are :
02-02-2012 12:09 AM
Sorry,
This is the request in the TFTp events:
Feb 2 07:06:29.598: TFTP: Looking for French_France/gb-sccp-sip.jar
Feb 2 07:06:30.866: TFTP: Looking for France/g3-tones.xml
the G3 tones is in the TFTP serverr but the gb-sccp-sip.jar is not there.
10-23-2012 11:33 AM
Did you get the file. Tell me did you finish with your phone. Me I am still in the same position .
Here's the log file from the TFTPD
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:96 [19/10 09:15:14.437]
Client requested address 0.0.0.76 [19/10 09:15:14.437]
DHCP: proposed address 192.168.0.105 [19/10 09:15:16.125]
1140 Request 2 not processed [19/10 09:15:16.140]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:07:7D:DF:C0:96 [19/10 09:15:16.203]
Previously allocated address 192.168.0.105 acked [19/10 09:15:16.203]
1140 Request 2 not processed [19/10 09:15:16.218]
1140 Request 2 not processed [19/10 09:15:16.234]
Connection received from 192.168.0.105 on port 43026 [19/10 09:15:20.046]
Read request for file
File
Connection received from 192.168.0.105 on port 54501 [19/10 09:15:20.296]
Using local port 1034 [19/10 09:15:20.296]
Connection received from 192.168.0.105 on port 55365 [19/10 09:15:25.468]
Read request for file . Mode octet [19/10 09:15:25.468]
File <\gb-sccp-sip.jar> : error 2 in system call CreateFile The system cannot find the file specified. [19/10 09:15:25.468]
10-23-2012 01:00 PM
You need to configure tftp-server correctly.
10-23-2012 01:23 PM
I think that I do it but I do not know if you can help me having this file to let the tftpd continue downloading the rest of files
File needed "gb-sccp-sip.jar"
10-23-2012 01:39 PM
It is contained in the rar file mentioned above.
10-23-2012 02:19 PM
I see that you're still experiencing problems with the locale as per your previous post. Please refer to the CME guide, particularly the section titled Using the Locale Installer in CME 7.0.1 or later. You need to download the full local tar files for 9.1 located below and extract the file locally on your pc. There are a number of individual country specific tar files for specific localisation, you simply need to upload the individual tar file of your choice to flash, there is no specific requirement to extract the files to flash. Follow the guideline for configuring cnf-files per phone and set user-defined locale, these are extract to the system/its for you now:
http://www.cisco.com/cisco/software/release.html?mdfid=277641082&flowid=5337&softwareid=282897001&release=9.1&relind=AVAILABLE&rellifecycle=&reltype=latest
Please rate helpful posts. Thank you.
Allan
10-23-2012 11:32 PM
I hope this new release file has the French language for SCCP 8941.
Because actual language have not the file requested by the IPPhone,
Antra
10-23-2012 11:45 PM
You can find the file in the release, from the link mentioned by Allan
Thank you very much.
regards,
Antra
11-13-2012 05:06 AM
Good Morning,
Please I would like to know how you can help to get this file. In my porject I had five 7942 to convert to SIP . I am done with this model now it is the turn for the CP-8941 and while running the process, The phone requires this file "gb-sccp-sip.jar" I have download the firmware from the cisco web site but to get the file that contains this needed file, I do not have the sufficient privillege. I have 6 days to fail or pass this project.
Thank you.
11-13-2012 05:10 AM
From what I know (I can be wrong), Cisco has never released language files for 79xx phones in SIP mode.
Localization SCCP mode is no problem, as long you have a support contract to access downloads.
