I have an IP Telephony setup on 2921 with Version 9.0
I have 8961 phone and need to configure speed dial on this.
I configured the following.
voice register template 10
button-layout 1 line
button-layout 2-4 speed-dial
voice register pool 6
fastdial 1 933512183 name nithin
fastdial 2 933512187 name louis
id mac 34A8.4EA6.808E
type 8961
number 1 dn 7
template 10
dtmf-relay rtp-nte
codec g711ulaw
But No luck......
Do i need to add anything more in the configuration????
BR...
Nithin Louis.....
Dear All,
Any Help???
Nithin...
I tried no create profile and create profile in the voice register global...but result same....
Hi Nithin,
Can you please try speed-dial instead of fast-dial
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Hi Rob,
Sorry for the delay.....
I tried the speed-dial instead of fast dial.But result is the same....
The Firmware version we are using is sip-8961-9-2-1.
Whether I need to change the FM or not ?
Thanks & Regards
Nithin Louis....
