8961 with CME 8.6
JessicaBroy82_2
I have an 8961 phone that I am trying to register with our CME 8.6 with no luck. It looks like the 8961 is supported using SIP firmware but when I enter the load 8961 command under telephony services I am not able to define the firmware. Can't figure out what I am missing. Any help would be greatly appreciated.
OS Description Cisco Internetwork Operating System
Cisco IOS (tm) C2800NM
Cisco IOS Software C2800NM-IPVOICEK9-M
Software Version 15.1(4)M / CME 8.6
Feature Package IP|VOICE|SSH|3DE
GUI Version 8.0.0.0 (Compatible with IOS 15.0(1)XA)
Jess
clileikis
Level 7
Level 7
Hi there,
If you're configuring a SIP phone, you'll need to use 'voice register global' instead of telephony-service.  See below:
R3-CME(config)#voice register global
R3-CME(config-register-global)#load ?
  3911       Select the firmware load file for 3911
  3951       Select the firmware load file for 3951
  7905       Select the firmware load file for 7905
  7906       Select the firmware load file for TNP 7906 phone
  7911       Select the firmware load file for TNP 7911 phone
  7912       Select the firmware load file for 7912
  7941       Select the firmware load file for TNP 7941 phones
  7941GE     Select the firmware load file for TNP 7941GE phones
  7942       Select the firmware load file for TNP 7942 phones
  7945       Select the firmware load file for TNP 7945 phones
  7960-7940  Select the firmware load file for Telecaster 7960 & 7940 phones
  7961       Select the firmware load file for TNP 7961 phones
  7961GE     Select the firmware load file for TNP 7961GE phones
  7962       Select the firmware load file for TNP 7962 phones
  7965       Select the firmware load file for TNP 7965 phones
  7970       Select the firmware load file for TNP 7970 phones
  7971       Select the firmware load file for TNP 7971 phones
  7975       Select the firmware load file for TNP 7975 phones
  8961       Select the firmware load file for RT 8961 phones
  9951       Select the firmware load file for RT 9951 phones
  9971       Select the firmware load file for RT 9971 phones
  ATA        Select the firmware load file for ATA
HTH,
Chris
Please rate helpful posts
Thanks Chris. I had to also enter in mode cme, after the voice register global command, but then I was able to specify a firmware load. Thanks for your help!
Great, glad I could help, thanks for the rating!
Chris
Has anyone seen a config guide or sample config for 8961 on CME 8.6?
