911 Dial-Peer Issue
mjerickson
I seem to be having an issue with dialing 911.  User is getting dialtone after dialing 911.  Here is my config.
dial-peer cor custom
name PSTN
name PBX
name VOIP
dial-peer cor list TargetPSTN
member PSTN
dial-peer cor list TargetPBX
member PBX
dial-peer cor list TargetVOIP
member VOIP
dial-peer voice 98 pots
corlist incoming TargetPBX
corlist outgoing TargetPSTN
destination-pattern 911
incoming called-number 911
port 0/0/1:23
forward-digits 3
dial-peer voice 99 pots
port 0/0/0:23
forward-digits all
Thanks in advance.
Mike
Can you remove the COR
and test again
no corlist incoming TargetPBX
no corlist outgoing TargetPSTN
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
11 Replies 11
acampbell
Mike,
Can you post
debug isdn q931 of a failed call
Also the config or info about your sytem
CUCM or CME
Alex.
Actually its a temporary Gateway that we have between an NEC and the PSTN , so we can strip DIDs off as people migrate to CUCM.  I will work on getting a debug.
Thanks.
Hi Mike,
Can you post a debug voip dial-peer and the q931 mentioned above.
Try adding direct-inward-dial to your dial-peers 98 & 99
HTH,
Chris
Here is the debug.
*Jul 19 10:18:15.507: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0xDFAE
        Channel ID i = 0xA98397
                Exclusive, Channel 23
*Jul 19 10:18:17.167: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8  callref = 0xDFAE
        Progress Ind i = 0x8488 - In-band info or appropriate now available
*Jul 19 10:18:17.175: ISDN Se0/1/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x8100
*Jul 19 10:18:20.831: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0200
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838D
                Exclusive, Channel 13
        Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
        Calling Party Number i = 0xA1, '651XXXXXXX'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '911'
*Jul 19 10:18:20.843: %ISDN-6-CONNECT: Interface Serial0/1/0:12 is now connected to 651XXXXXXX N/A
*Jul 19 10:18:20.847: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8200
*Jul 19 10:18:20.847: ISDN Se0/1/0:23 Q931: TX -> CONNECT pd = 8  callref = 0x8200
*Jul 19 10:18:20.931: ISDN Se0/1/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0200
*Jul 19 10:18:31.439: ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8  callref = 0xDF9F
        Cause i = 0x8190 - Normal call clearing
*Jul 19 10:18:31.439: %ISDN-6-DISCONNECT: Interface Serial0/1/1:0  disconnected from 4525 , call lasted 942 seconds
*Jul 19 10:18:31.443: ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8  callref = 0x5F9F
*Jul 19 10:18:31.447: %ISDN-6-DISCONNECT: Interface Serial0/0/1:0  disconnected from 612XXXXXXX , call lasted 942 seconds
*Jul 19 10:18:31.451: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8091
        Cause i = 0x8090 - Normal call clearing
*Jul 19 10:18:31.499: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x0091
*Jul 19 10:18:31.503: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8091
*Jul 19 10:18:31.539: ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xDF9F
Mike,
We see the call is incoming on
S0/1/0:23
Which dial peer do calls on PORT 0/1/0:23 match
Think you will need to provide more or all of show run
Alex.
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
h323
modem passthrough nse codec g711ulaw
sip
voice translation-rule 3
rule 1 /7029/ /6515237029/
voice translation-profile profile1
translate calling 3
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description PRI coming from the PSTN
controller T1 0/0/1
framing esf
linecode b8zs
controller T1 0/1/0
framing esf
clock source internal
linecode b8zs
description To Switch
controller T1 0/1/1
framing esf
linecode b8zs
interface FastEthernet0/0
ip address 10.220.41.99 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
interface Serial0/1/1:23
no ip address
encapsulation hdlc
no cdp enable
ip default-gateway 10.220.41.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.220.41.1
ip http server
no ip http secure-server
logging 10.1.1.95
snmp-server community OSIMonitor RO 5
control-plane
voice-port 0/0/0:23
voice-port 0/1/0:23
voice-port 0/0/1:23
voice-port 0/1/1:23
name PSTN
name PBX
name VOIP
member PSTN
member PBX
member VOIP
dial-peer voice 6 pots
description Outbound
destination-pattern [2-9].........$
incoming called-number [1-7]...$
direct-inward-dial
port 0/0/0:23
forward-digits 10
dial-peer voice 7 pots
direct-inward-dial
port 0/0/1:23
forward-digits 10
dial-peer voice 8 pots
destination-pattern [2-9]......T
direct-inward-dial
port 0/0/1:23
forward-digits 7
dial-peer voice 9 pots
direct-inward-dial
port 0/0/0:23
forward-digits 7
dial-peer voice 10 pots
corlist incoming TargetPSTN
corlist outgoing TargetPBX
description Inbound Dialin
translation-profile incoming Outbound
destination-pattern [1-7]...
incoming called-number .
no digit-strip
direct-inward-dial
port 0/1/0:23
dial-peer voice 11 pots
no digit-strip
direct-inward-dial
port 0/1/1:23
dial-peer voice 22 pots
description Outbound LD
destination-pattern 1..........
no digit-strip
port 0/0/0:23
dial-peer voice 23 pots
no digit-strip
port 0/0/1:23
port 0/0/1:23
forward-digits 3
port 0/0/0:23
forward-digits all
dial-peer voice 411 pots
destination-pattern 411
incoming called-number 411
port 0/0/1:23
forward-digits all
dial-peer voice 36 voip
description Connection to CUCM
destination-pattern 6787
session protocol sipv2
session target ipv4:10.1.100.31
dtmf-relay h245-alphanumeric
dial-peer voice 35 voip
destination-pattern 7029
dial-peer voice 37 voip
destination-pattern 6631
dial-peer voice 38 voip
destination-pattern 6701
dial-peer voice 39 voip
destination-pattern 6618
dial-peer voice 40 voip
destination-pattern 6703
dial-peer voice 41 voip
destination-pattern 6612
dial-peer voice 42 voip
destination-pattern 6660
dial-peer voice 43 voip
destination-pattern 6641
dial-peer voice 44 voip
destination-pattern 6684
dial-peer voice 45 voip
destination-pattern 6705
dial-peer voice 46 voip
destination-pattern 6663
Mike
Can you add the following as Chris showed earlier:-
direct-inward-dial
direct-inward-dial
Test again
Alex.
Still failing.  Here is the debug.  Thanks.
*Jul 19 11:37:42.339: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0100
                Standard = CCITT
        Channel ID i = 0xA98382
        Calling Party Number i = 0xA1, '651XXXXXX'
*Jul 19 11:37:42.355: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8100
*Jul 19 11:37:42.363: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8100
        Cause i = 0x8281 - Unallocated/unassigned number
*Jul 19 11:37:42.471: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0100
*Jul 19 11:37:42.475: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8100
*Jul 19 11:37:50.431: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0100
                Standard = CCITT
Mike
and test again
Alex.
That did it. Thanks.
Is there a resource for Dial-Peer config?  Its either a practice thing or compreshension for me.
Mike,
glad it helped.
There are many sources of information for dial peers
here are a couple
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dpeer_c.html
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Alex.
