99x1 blind transfer
Andrej Grcman
did anyone figure out the procedure or settings combination on Cisco 9951 phone that would enable user to do a blind transfer to phone number in Corporate directory?
Transfer procedure starts nicely by pressing Transfer hard key, but after user presses Directory hard key, transfer procedure is cancelled.
brmeade
Level 4
Level 4
No way to do this via blind transfer.  CSCuc21228 is an enhancement request filed to allow that.
You should be able to do consult transfer still:
1- with an active call, press the transfer button.
2- Contacts button.
3- Corporate directory.
4- Find User
5- Call that user
6- when the user answers, press on Transfer button again and then the Button next to the first call and the call will be transferred to him.
brmeade
Level 4
Level 4
2- Contacts button.
4- Find User
5- Call that user
Thanks for your reply and opening an enhancement request. Bug is present also on firmware 9.4.1.9.
I figured the way around using the attended transfer (as you have pointed out), but it's not ideal.
Best regards,
Andrej
