07-31-2013 01:55 AM - edited 03-16-2019 06:38 PM
Until now all the sites used u-law where i worked. I have a requirement where one country telco uses a-law standard. Is there any configuration that i need to put in place on the VG to support a-law or the ISDN PRI does the voice encoding
07-31-2013 02:05 AM
You have 2 options on how you configure codec for voip leg of the call.
1) On the voip dial-peer you configure the specific codec to be used. Here for this setup, you can configure the DP as codec g711alaw".
2) Creae a voice class codec and configure all the codecs you want to available for negotiation and configure the DP to use the same voice class codec.
Check the following link for sample of voice class codec config:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00800b6710.shtml#cod_neg
07-31-2013 02:10 AM
Thank You. Yes am aware of this. Am talking about the telco end. Will this config suffice or any other config required.
07-31-2013 02:25 AM
You dont need to do anything on Telco end. Depending on the region, the telco would choose which codec needs to be used. The VG is configured to support the codec as sent by the telco.
07-31-2013 03:53 AM
Telco will send the "wish list" codec, but ultimately it is upto your router will chose the codec based on the voice class class codec configured on your router. This will be sufficient.
Please rate if this helps.
07-31-2013 04:50 AM
I work in the UK - we are an ISDN PRI E1 country - Alaw is used over the PSTN.
We need to use ulaw internally to allow old unity servers to communicate
Here is sample of a config with the CPTONE as GB (Other name for UK)
controller E1 0/0/0
description ISDN for PSTN ISDN CCT 222222
pri-group timeslots 1-8,16
linecode hdb3
framing CRC4
clock source line
interface Serial0/0/0:15
no ip address
no logging event link-status
isdn switch-type primary-net5
isdn overlap-receiving
isdn overlap-receiving T302 2000
isdn incoming-voice voice
no cdp enable
voice-port 0/0:15
echo-cancel coverage 32
no vad
cptone GB
voice call carrier capacity active
voice rtp send-recv
voice call convert-discpi-to-prog
!voice call send-alert
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
dial-peer voice 1 pots
description *** INCOMING CALL MATCHING ***
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 9 pots
description *** O/G LEVEL 9 TRAFFIC TO PSTN ***
destination-pattern 9T
tone ringback alert-no-PI
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
dial-peer voice 11 voip
description *** DDI RANGE 332000-332999 ***
preference 1
destination-pattern 332...
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.12
dtmf-relay h245-alphanumeric
ip qos dscp ef media
ip qos dscp cs3 sig
no vad
dial-peer voice 12 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.11
ip qos dscp cs3 sig
no vad
Alex.
Please rate useful posts.
07-31-2013 05:23 AM
Hi Alex,
Thanks for the information.
