Abbreviated internal dialing with CME
aoster
Hello all,
I am currently searching for an easy solution to allow CME users to dial each others seven digits
internal extensions as an abbreviated, shorter version using "*" as the first digit folloed by the last
three digits of their extension. Currently only the last three digits are different for all extensions so
I thought about a translation rule like:
voice translation-rule 1
rule 1 /^*\(...\)/ /100\1/
voice translation-profile abbrvDial
translate called 1
Is it possible on CME to use a dial-peer to translate the called number for internal calls ? If so how does
the dial-peer have to look like ?
Thank you for your kind help.
regards
Andreas
Jonathan Schulenberg
To answer the original question: yes you can do that. You would associate the translation profile on the ephone-dn or ephone-dn-template. IMO it's easier to centralize this sort of thing onto a dn template.
ephone-dn tag
translation-profile {incoming | outgoing} name
Another option you can try is to use the dialplan-pattern command. This should allow you to get it done in a single command vs. adding a bunch of speed dials.
telephony-service (or voice register global)
dialplan-pattern 1 100.... extension-length 4 extension-pattern *.... no-reg
Please remember to rate helpful responses and identify helpful or correct answers.
9 Replies 9
paolo bevilacqua
No translation rule is needed, you can configure these a global speed-dial, and then press softkey AbbrDial to call.
Or you can configure a secondary number the 3 digits extension and achieve the same.
Hello Paolo,
thank you for your fast response. The global speed-dial sounds good to me,can you
point me to some documentation or give a shot example how this is done ?
Thank you very much.
best regards
Andreas
Hello Paolo,
would something like that work ? :
abbrvList:
100,1000100,user1,,
101,1000100,user2,,
102,1000100,user3,,
103,1000100,user4,,
telephony-service
bulk-speed-dial list list-id flash:/abbrvList
bulk-speed-dial prefix prefix-code *
Andreas
You can use that or if isn't t than many, the speed-dial entries under ephone-template.
Please remember to rate useful posts clicking on the stars below.
ephone-dn tag
Hello Jonathan,
thank you very much for your help. I will implement the translation rule using the ephone-dn-template.
Obviously I have to ask the users to utilize another digit for abbreviation dialing ( mybe '9' )  as the *
is not allowed in translation rules.
best regards
Andreas
It is allowed, prefix with \.
Hello Paolo,
thank you very much for this info it actually works with:
rule 1 ^\*\(...\) /1000\1/
best regards
Andreas
aoster wrote:
Hello Paolo,
Actually that can be be written more concisely
rule 1 /^\*/ /1000/
