ā04-23-2012 07:49 AM - edited ā03-16-2019 10:46 AM
Hi all,
I have added one sip extension on cme. Whenever i dial outsdieby dialing 9, it omits digit 9 and finally i cant recall that number. any Clue?
ā04-23-2012 07:51 AM
Try
voice service voip
sip
no update caller-id
ā04-23-2012 09:53 PM
Its not working.
Following is the sip setting
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
no update-callerid
Following is the dial-peer
dial-peer voice 10 pots
trunkgroup FXO
description GSM
destination-pattern 903.........
forward-digits 11
Following is the phone setting
voice register global
mode cme
source-address 192.168.X.X port 5060
max-dn 5
max-pool 5
authenticate register
voice register dn 1
number 1234
name test
voice register pool 1
id mac 1234.F219.0A2A
number 1 dn 1
username 1234 password 1234
codec g711alaw
ā04-23-2012 10:16 PM
forward digits is 11, the extension is 12 digits, so it will omit 9 when make outbound call.
ā04-24-2012 03:46 AM
I'm afraid that you did not understood OP question.
ā04-24-2012 09:54 PM
i think its matter of global digit normalization.
ā04-25-2012 01:19 AM
Could see,
trunkgroup FXO
description GSM
forward-digits 11
There are 2 ways to send 9 here
1.
trunkgroup FXO
description GSM
forward-digits 12
2.
trunkgroup FXO
description GSM
forward-digits 11
Prefix 9
Siva
Please rate if helps you.
ā04-25-2012 01:47 AM
Zhen Huang & Sivakumar Shanmugam this is not the matter of sending the digits but to match E.164 dialing pattern.
